Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
Subscription channels not working
david888
Just got back from holiday and discovered that all subscription channel recordings failed since 20 November.  Viewing such a channel live shows error code IPC6023. Since then I have restarted the Youview box and reset the router. Still the same error. Youview box is connected to the router directly via ethernet cable. Internet itself working fine. Would appreciate any help from an OCE.
I've updated the router firmware.
Can you power off the router and TV box at the mains for a full 30 minutes.
This will allow the exchange session to close.
Then restart the equipment and retest.
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
david888
Hi Karl,
I have two HG633 routers. The one that is currently plugged in whose firmware you have just upgraded is the spare. The one that was plugged in while I was on holiday when the TV stopped working was already at v1.22.1t. I plugged in the spare which runs with factory settings to rule out a router problem. However, I will unplug everything for 30 minutes and let you know if it has solved the problem. Thanks.
david888
Hi Karl,
Both router and Youview box have now been turned off at the wall for well over 3 hours. Unfortunately, it has made no difference. Still getting the IPC6023 error.
All tests are showing clear and the connection looks fine.  I've a different model router on the way to you to see if this corrects the problem.
david888
Thanks, Karl
No Problem 🙂
The 6023 error is a communication error between the box and the server, so can be caused by the router or other issues that can impact the connection.
If there was no error but just a blank screen then this would point to a multicast transmission issue, so we have to look at this as a connection issue.
david888
Hi Karl,
The new router came but it didn't fix the problem (the same IPC6023 error as before). Any further thoughts?
Did you swap over the ethernet cable to the box ?
Are the on demand players working, IPlayer etc?
I do see an increase in connection drops, so next option is to look at an engineer.
To do this can you confirm:
To confirm you're the account holder can you PM (Personal Message) me with the following information:
  • Full Name
  • Home telephone number
  • Are you the account holder
  • How do we send the bills to you each month
  • What package do you have with TalkTalk
    Note: Please do not post personal information directly in the Forums.
david888
Hi Karl,
To answer your questions:
1) I did not swap over any ethernet cable because the cable between the router and the Youview box is a long one. However,
2) On demand players are all working fine
3) I seriously doubt that it is anything in my home that is the cause of the problem, but if an engineer visit is necessary, so be it. I accept potential engineers charges. I am available anytime except Fridays.
At the meantime, is it ok for me to disconnect the D-link 3782 router you sent me and put the HG633 back on? The D-Link has a bug that stops a PPTP connection from working. This is a showstopper for me.
An appointment has been scheduled for Tomorrow 7th Dec PM (1-6).
david888
Hi Karl,
The engineers have just been and couldn't find anything wrong with the broadband or my equipment. They said the multicast TV signal is controlled by TalkTalk. Please could you check your end again for possible account misconfiguration or provisioning errors? Thank you.
I've asked if we can get a multicast engineer to the exchange to verify the TV traffic can be seen across the port.
david888
Hi Karl,
I presume the multicast engineer hasn't visited the exchange yet as the boost channels are still broken as of this morning. Any idea when this visit is scheduled to happen? Thanks.
Multicast engineer has visited exchange and found an issue and passed this to another team within BT.
I'll email our network teams to chase for an update.
david888
Hi Karl,
Thanks for the update. Please keep me posted.
david888
Hi Karl,
Any progress on this? Is there a website or a phone number where I can go to to enquire about the status of this repair? What is the ETA of the my TV service resuming? Thanks.
Hi david888
I've chased this up with Openreach today. They are now advising they have cleared the fault at the exchange.
Can you switch off the router and TV box at the mains for 30 minutes, then power back on and retest.
david888
Hi Karl,
I powered off both router and TV box for 1 hour at the wall and powered them back on. Unfortunately I am still getting the dreaded IPC6023. Did the Open Reach engineer actually check for the presence of a multicast signal at the exchange?
BT advised the multicast issue at the msan was cleared.  I've escalated this back to them confirming your fault still remains and they need to look specifically at your circuit and test to see if there are any multicast issues across your port.
