Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
TTG 238
ANSWERED
Steveng
Hello. I am using my old BT Humax box for the talktalk service as the Huawei box sent by talktalk is inferior (poor picture quality, slowing moving picture). I am now getting a TTG 238 error message saying the service is only available on my main youview box. I only use one box, how do I get the settings change for this box to be the main box. The website offered in the message is no help whatsoever!
spock146
Same thing on my new bt youview box. it has been working flawlessly for the last 2 weeks including Netflix which does still work. Spent what felt like an hour going through all the fault checks despute just requesting changing the primary box.
Please can someone just change the registration over to primary
youview box is drtr2110
spock
Steveng
Anyone from talktalk want to help us out?
Solution
Hi Steveng & Spock 146
I've set the humax as the primary box for both of you.
Check & Report l Our latest Blog l Share your Ideas l Service Status l Help with your Service l Community Stars
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
Steveng
Thank you, all working fine now!
spock146
thumbs up at this end, many thanks
spock
Chris__M
Is it really that easy to switch the Humax to be the main box?
I had exactly this issue - I have both a retail Humax box (DTR-T1000), and a TalkTalk Huawei box. Like many, I far prefer the Humax.
Back in December, I called TalkTalk support, asking if it was possible to make the Humax the main box. I was told yes, and that they would do it for me. Their first attempt  failed to do anything. Their second attempt resulted in *both* boxes giving the TTG238 message - i.e. neither appeared to be main.
Support said they didn't understand why, and would escalate, and someone would call me back. No-one did, and we spent Christmas and the New Year without the included Sky Channels.
Yesterday, I spent 2 hours (really, I don't exagerate) on the phone to support - in all, I spoke to 4 different people, being shunted from person to person. I kept explaining "Sky worked on the Huawei box before you changed it in December, can we simply reverse that change?" One guy started asking me to disconnect all my equipment, saying he would teach me how to connect it to the internet properly (ignoring my insistance that all standard online players worked, and that Sky had previously worked); the guy who he passed me onto tried to get me to authorise 55 quid for an engineer to call; the next guy latched onto the fact that I don't use a standard TalkTalk router, and that was the cause, despite me telling him (a) it had worked previous to the changes support had made in December (b) the router hadn't changed in the meantime (c) I understood IGMP and had it configured correctly (he didn't know what I was talking about).
Finally, I got through to someone who could help, by being rude (not my usual approach) and insisting on speaking to someone senior. Even then, I had to explain from scratch (yet again) and explain (a) yes it did work previously (b) I can see the internet; (c) no, it is not my router. Finally at 2 hours 20 minutes, he switched back my Huawei as main, and I could see Sky again - not on my preferred box, but at least I had the channels back, after weeks without service.
I guess I should have tried the community first (this is my first time here), but I kind of assumed the official TalkTalk support line was the way to go. Now reading this, I feel ever so frustrated.
Hi, sorry to hear this.
If you do want me to confirm the box is set as the primary, can you confirm the last 8 digits of the box identifier.
This can be found : Y Button > Settings > System Information > Device Information.
cwillk14
mine also needs changing, i was on the phone to talktalk yesterday for over 30 mins & they were absoutly useless, they have never heard of error code ttg 238 & couldnt understand what the problem was after i read the error messege to them 3 times! fed up with this now how hard can it be???
Chris__M
Karl  - many thanks. Am out and about this weekend, but will post the numbers either tonight or tomorrow.
cwillk14
My last 8 digits are 0104d94c
Hi cwillk14,
Can you please complete your Community Profile and we'll take a look at this for you. :)
Hi Chris_M
OK, thanks :)
kaz32
hi am having same problem i also only have one tt box in house was working fine up until two days ago
can you start your own thread (New Message)  so we can deal with this for you.
Posting in other threads makes it difficult to follow the conversation and for others when searching for a solution.
Many Thanks
Stroppychild
Hi could you please set the following box as my primary box. Model DN370T.02.04.P, serial number F8R8WF12B0914969, Identifier 001882-DN370T01-010f2151.
Shaun
benjacko78
i've got asked promlem   i've  got  a free view box in bedroom what i put in there and talktalk box in living room  up to yestoday it's been working fine  and today  trying to watch on demand on youview box  it say it's not my main box and can't watch demand on it
 anybody help pls
