TV Access Charge Opt Out
3 REPLIES 3
Rod424
I have been reading the variuos messages on the forum and have noticed how Karl has been able to help those who do not wish to use the TV services covered by the £4 access charge.
I only use Freview and the internet players. I have noted which facilities I will loose but would still like to opt out.
I would be most grateful if this could be arranged for me.
Cheers
Rod
I can opt you out of the upcoming TV charge but I'll need to confirm some security details to access your account.  I'll send a PM separately with the info required.
Please note however that when you opt out of TalkTalk TV you will lose access to add and remove TV Boosts flexibly.  You will lose access to TV Boost on demand content via the TalkTalk player.  You will also lose access to TV on the go services via the web and Mobile App.
Also, any current recordings you have made from a Boost channel will stop working when you are no longer subscribed to that channel.
Rod424
Many thanks for your prompt reply.
I have sent a PM with the information you requested.
Cheers
Rod
I've processed the request for you now.
