TV BOX will not startup how do I get a replacement
Hello
My TV BOX will not startup and I have tried all the recommended resets.
It is HUAWEI model DN372T
How do I get a replacement?
I've escalated to the OCE for you.
For a quicker reply can you please ensure you have your personal information up to date in your profile. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profileersonal-info
If you are unsure of your phone number, dial 17070 from your land line phone and this will confirm the number for you.
Thank you
I'm assuming you have tried all of the following?
A soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
Can you please add your home phone number or Account number to your Community Profile so I can locate your details.
If unsure of your phone number, simply dial 17070 from your land line phone and this will confirm the number for you.
