TV Box Issues
4 REPLIES 4
Over the past 2 months i have had several issue swith my youview box. I have had to do 3 factory resets as the nothing i recorded would play, wouldnt do anythingeven after a reboot and the third because of the lost channels, and now over the last 2 weeks i have to hard boot my device 4 or 5 times which i am getting sick of doing. Is there a permant solution for this issue?
The box is model number DN372T.01.02.P, Variant 1
The omponent software version 3.5.116 (9deb70)
The manufacturer software version is 72.47.119
The platfrom Configuration is 4421
James
I see that you started a topic towards the end of October and you were advised to try a maintenance mode reset, but you did not respond in that topic further. Have you tried that?
yes i did and that got me up and running for about a week, I work long hours and am not always able to do things straight away and totally forgot i asked about this in october, too many things on the brain to do with I.T. related issues, posts that i forget about the post for this in October i made.
No worries, I understand, sometimes it helps though to have a bit of continuity for the benefit of the support team.
This won't be picked up again until Monday now I'm afraid, but I have flagged this up and you will get a response.
Hi jwaugh77
The next option is to swap out the box.  I'll arrange this for you.
