TV Box problem
11 REPLIES 11
My talk talk TV box is not able to get freeview channels and also have problems with HDMI cable.
I have factory reset the box and also changed the HDMI cable with no effect.
I have a blank screen with no audio or video signal.
Please advise. Does the TV box have these faults commonly seen by others as well?
Have you tried another HDMI port on the TV ?  Is there anything on the screen when you press the youview button, any menu item showing etc ?  Has this worked previously on this TV ?
Hi Karl,
Yes i have tried a different HDMI cable with no change. The screen remains blank with no menu items that show up when you press 'youview'.
Yes it has been working for the last 6 months and stopped suddenly 2 days ago.
Many thanks
Can you check the home phone number on your profile, I'm not linking that to a live account.
I have updated my home phone no. on the profile.
OK, I'll get the box swapped out for you.
thank you , hope it works
No Problem 🙂
I'm having the same issue was told an engineer needs to Come out first 🙄 it's very annoying as I only have Saturdays off and my partner is free Monday if they can send me a replacement box I can install it myself
@Grant123  Start your own topic and the support team will gladly look into this for you.
How do I start a new topic?
Hi @Grant123
Click on the TT TV at the top oof this page and you will see a blue box marked "start a topic". Click on that and away you go.
