TV Plus Box Not Recording
ANSWERED
6 REPLIES 6
neiland mo
The TV Plus Box says it is set to record but fails to do so.
Have tried re-set and all other suggestions in help, but to no avail.
Box is approx 8 Years old.
Very Frustrated
Solution
Can you confirm you have tried a full factory reset from the the settings menu, as this reformat the hard drive and repairs and sectors and does sometimes work. You will lose your recordings, but you will also do If the box is replaced, so have nothing to lose.
If that does not work, you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
neiland mo
I am reluctant to try factory re-set at the moment, as have some recordings of grandchildren on there when they were on TV, going to use my phone to film the programmes as soon as I can.
The box is actually recording (sorry about the confusion), the problem is they are listed in My TV but when you try to play a recording, only get a blank screen. If we turn off power at rear of box and the box reloads (which takes about 5 mins and annoying), we can watch one of the recordings, if we then try and watch another, blank screen again, so have to switch off at back again-another 5 minutes re-loading. As we have about 60 hours of different recordings this is quite tiresome!
OCE_Karl
OK, but if the issue continues the full factory reset may be the only option left to clear any corruption on the hard drive.
neiland mo
Have now carried out a factory re-set. When I try to watch tv (via the tv's own tuner) no signal message, have tried various leads to no avail! Suspect box is not allowing tv aerial signal pass through (which it did before factory re-set). Wife is giving me earache as no recordings and no tv signal pass through, have by-passed box and connected tv direct to aerial. Works perfectly, so box is useless!!!
You need to change your box settings.
The main one here is to turn antenna out ON via the settings menu.
OCE_Karl
As fr8ys advises, the antenna pass through is not enabled by default and needs turning on in the settings.
