Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
TV Plus Box freezes - need a replacement box
1 REPLY
nicholasareeves
I have had my TV Plus Box a long time now and in the past, when I have had problems with the box freezing, I have done a factory reset and everything has worked again. However, the freezes returned a week ago and I have now reset the box three times - each time it works OK for a while and then it freezes return. As I have been a TalkTalk customer for many years and have had this TV Plus Box since it was first released, would it be possible for me to be sent a replacement box?
Many thanks in anticipation that an OCE can arrange this.
Nicholas
nicholasareeves
I posted this on Sunday and have not had any response : as I explained in the original post I have had to do a factory reset three times in a week because the box kept freezing : I think each time it happened when I tried to change channel and discovered that the box had frozen. If an OCE could look at my account you will see that I have had this TV Plus Box for many years and I assume it's come to the end of its life. In the past a factory reset would solve problems like this for  many months - sadly not this time!
