I've got a problem with my TV Plus box. It keeps stopping responding to the remote control and now it won't start up. I have been through all the options on the maintenance menu, but it goes through the start up procedures each time, but then goes back to the screen saying there was an error in restarting and so I go through the whole process again. Intermittently when going through the processes I get a bright green screen for a couple of seconds. As I say I have tried all the usual turn off procedures and all the maintenance steps, I don't know what else to try. Do I need a new box? Any help would be appreciated. Cheers.
Can you please add your home phone number or Account number to your Community Profile.
We will not attempt to call you, this is so we can locate your account and run tests on your line if required. We will then reply via this Community.
If unsure of your phone number, and if your line is working simply dial 17070 from your land line phone and this will confirm the number for you. Alternatively these details can be found within My Account online or may be on the heading of any paperwork you have received.
Hello Karl, thanks for getting back to me, I have added my home phone number as requested. Thanks.
Hello Karl,
I don't know if it's connected to the problem, but the box is getting quite warm/hot at the back. Cheers.
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
No Problem 🙂
Hello Karl, the new box arrived this morning, thank you very much. However after setting it up and re-tuning the channels a couple of times, there are no HD channels coming up at all. How can I get the HD channels back again please.
Regards.
Jim
Try this: pull the aerial out from the back of the box; do a full channel retune; that will obviously bring up no Freeview channels at all, but should clear the tuner memory; plug the aerial back in and retune again. Let us know how you get on.
Tried that but unfortunately it didn't work. This is a new box that arrived this morning.
OK. Did the previous box pick up all the missing channels OK? Does your TV do so? Subject to that wait for further advice from the OCE.
Ah, OK. There have been a lot of retune events in recent months, it may be worth checking via Freeview what channels you can expect and whether there is more than one transmitter covering your area.
https://www.freeview.co.uk/help
EDIT: Once you have got your postcode result scroll down the page and click on Detailed view.
OK, are all the non-HD channels available on your TV, or are any of those missing as well?
