TV Set top box is not working
3 REPLIES 3
TATTS1
It says the box failed to start properly.  I've tried to update the SW but no luck.
Is it possible to get a new box?
TD
OCE_Karl
Can you please add your home phone number or Account number to your Community Profile so I can locate your details.
If unsure of your phone number, simply dial 17070 from your land line phone and this will confirm the number for you.
Steve_01
My set top box stopped working got as far as maintenance service lights flashing all day but nothing happening
S Demetriou
fre55die
Hi @Steve_01
Could you please start your own thread for support as each problem is individual and needs investigating separately.
IMPORTANT
Could you please also ensure that your community profile includes your PHONE NUMBER as OCE's will need this to tie up your screen name to your account. (click on your avatar to view the information > Settings > Launch Profile Wizard,put your phone number in box, then scroll to the bottom of page and click save) Only you and the OCE's can view this information.
