My TV box keeps getting stuck in a loop between the Huawei and youview screens and just keeps restarting itself. Box will work fine sometimes but happens frequently and becomes temporarily unusable sometimes for hours, seems to be getting worse. Could I get a replacement box sent out or something?
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works but if not then please let us know and I’ll flag for further assistance.
Oh, and you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
Hi Robbbin
Try the resets as advised and let us know if this helps.
Hi, I’ve tried all the resets advised but am unfortunately still having the same issues.
Can you please add your home phone number or Account number to your Community Profile.
We will not attempt to call you, this is so we can locate your account and run tests on your line if required. We will then reply via this Community.
If unsure of your phone number, and if your line is working simply dial 17070 from your land line phone and this will confirm the number for you. Alternatively these details can be found within My Account online or may be on the heading of any paperwork you have received.
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
Good afternoon,
I have similar issue. I have reset the device in any possible way and it will not start entirely. It switches between Huawei and Wake Up screen.
Please would you be able to assist?
