TV box not working
5 REPLIES 5
thomasj
See a couple of people with the same problem as me, box working inconsistently, and now won't record.  Not sure how old it is but I've had it a few years, possibly starting to fail?
Thomas J Marshall
If you can be a bit more specfic about the issues you are having, along with any error codes you might be getting, that will be helpful. Have you tried a maintenance mode reset?
https://support.youview.com/youview-box/box-and-remote/using-maintenance-mode
thomasj
Box reset several times but the problem remains. Aside from the slow response and occasional freezing that requires a restart the box will not record. Pressing record shows the usual red dot but the recordintg lights do not come on and it does not record.
Thomas J Marshall
OK, let's wait for the support expert here to have a look, it is unlikely to be before Monday though.
thomasj
OK thanks.
Thomas J Marshall
Hi thomasj
Have you tried the full factory reset from the Youview settings menu ?
This will wipe and reformat the hard drive and set this back up.
