Search instead for
TV box stops working, needs rebooting every hour
Joserj
Our Talk Talk TV box stops working, remote doesn’t work after one or two hours of viewing, have to reboot and start again. Have tried batteries, reset remote, retuned, and numerous reboots using button at front, at back and power switch. Seems to be since upgrade.
Can you please add your home phone number to your Community Profile so I can locate your details.
If unsure of your number, simply dial 17070 from your land line phone and this will confirm the number for you.
Please reply when this has been updated.
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
Joserj
This has been updated. Thanks
Hi Joserj
I've updated the router firmware, test today and see if the connection is more stable.
Joserj
No, sorry, still having to reboot a lot. Had to be rebooted to start, then may stop being able to change channels so have to reboot again.
Have you performed a Youview Maintenance Reset (Option 4: Keep Recordings).
If this has been tried and still failing, as a last option you should try the factory reset from within the youview menus.   This option will wipe and reset the harddrive, but should only be done if the maintenance reset fails to resolve.
Joserj
I’ve had to do a factory reset which has helped somewhat but I now cannot record anything. I’m getting a ‘please try later message’.
Joserj
We’ve done factory reset and are still having the same problems with control only working a few times, then stops.
Joserj
It’s worse again - will do about 3 functions after a reboot then stops changing channels etc,
Joserj
Not working at all now.
Joserj
We have no Talk Talk TV, very poor broadband. Please can you tell me how I can cancel. Thank you.
Hi Joserj, are you really looking to cancel or are you happy to try a new tv box?
Joserj
We would like to try a new box please.
A box is on the way.
