TV box
ANSWERED
4 REPLIES 4
Visitor
My TalkTalk TV Box has died completely (although the power pack is still live). How do I get a new one?
Can you confirm the box is getting no power at all. If not,
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
Visitor
The power supply is live but the box is as DEAD as the Monty Python parrot, so how do I get a replacement?
You will need to wait for a staff member to respond, early next week hopefully.
Solution
Hi Aristotle1
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
