TV light out on router
SHurt77
Thanks @fre55die I've tried the 30 mins and hard reset and I'm still in the same place here.
The old and new routers had completely different names and passwords if that helps. The new router doesn't even appear when plugged in.
pete 1
I had the same issue as you many years ago, All the neighbor's wifi would show on the drop-down list except mine. I spent many hours on the phone with TalkTalk advisors blah blah blah, the end result was a replacement router.
You can see on the screenshot how good my neighbors TalkTalk signal is, the same as mine.
SHurt77
Thanks @pete 1 maybe that's what I'll have to do. It seems a shame as this new router is less than a month old.
pete 1
OCE-Carl has been excellent in helping me out.
Maybe he can remotely access your Hub to see if for some reason that the Wifi is off.
SHurt77
@OCE_Karl are you able to help?
Thanks again @pete 1
OCE_Karl
Have you tried a pin reset of the router - hold a pin or paperclip in the reset hole at the back for 10 seconds and this will fully reset the router.
Try this and see if wifi is then enabled.
SHurt77
@OCE_Karl yes I have tried that a few times, still nothing. Again TV good no WiFi.
Thanks for getting back
OCE_Karl
I'll request a router is sent to you.
SHurt77
Ok thanks a lot @OCE_Karl
Let's hope that sorts the problem out.
Cheers
OCE_Karl
No Problem 🙂
SHurt77
Hi @OCE_Karl
I've still not received the router. Could you let me know when it is due please?
OCE_Karl
I was advised by our logistics teams one would be sent.  I'll go chase this up with them.
