Talk Talk TV Plus box not working
4 REPLIES 4
lightening
Hi. My Talk Talk TV Plus box has stopped working. There are no lights and is not connecting to the TV.
I have:
-Tried another socket. No difference.
- Switched off using the master switch on the back, waited 30 minutes and switched back on  at the back and at the front.
Box gets warm but still no lights on the front of the box and no connection to the TV.
Can you please send a replacement box.
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
OCE_Karl
Hi lightening
A TV box is on the way.
lightening
Thanks for the very prompt response. Box rec'd and back up and running.
Perfect!!
Thanks very much.
OCE_Karl
No Problem 🙂
