Talk Talk box not working
7 REPLIES 7
Box failing to record most of the time.
Locks up and won't turn over channel unless switch on off at back of box which then takes ages.
Generally slow
Julie Dawn Pimlott
Have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works but if not then please let us know and I’ll flag for further assistance.
Hi Julie
try the reset as mentioned and let me know.
We have tried maintenance reset and factory reset several times.. now failing to record most programmes and cannot change channel without waiting an hour or so. At the end of our tether. Now 😠
Julie Dawn Pimlott
Karl, we have tried maintenance and factory resets, it's hardly working at all now.
Julie Dawn Pimlott
Can you add the home phone number to your 'Community Profile' rather than the mobile, so I can locate your account.
I have changed now. Thank you Karl
Julie Dawn Pimlott
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
