TalkTalk TV Plus Box Fails To Record
8 REPLIES 8
My TalkTalk TV Plus Box has failed to record any programmes from any channels since May 10th 2020. Tried everything except reboot, as don't wont to get rid of some saved programmes from before.
PLEASE HELP!!!!!!
I have had other issues, connection problems for months, two engineers visits, new Modem [March 2020], new phone line, upgrade to Fast Fibre [April 2020], line check still saying fault and engineer arranged to be sent out today within in next 2 days one hour after last engineer left, at wits end!!!!!!!
Sorry to hear this.  Do you mean you have an engineer arranged to come out in 2 days (Thursday).
Hi I have now got a text saying engineer fixed problem so  I should check home set up. I have done this You View Box still failing to record. Please provide new TV plus box.
Can you please add your home phone number or Account number to your Community Profile so I can locate your details.
If unsure of your phone number, simply dial 17070 from your land line phone and this will confirm the number for you.
The engineer came to fix the ongoing problem I have had of the internet dropping out. He found a fault on the phone (a crackling) and fixed it, and got the broadband speed up again from 5 to 30. However since he left the internet has continued to drop out occasionally, not every 5 mins as before but now 2 or 3 times a day.
I did mention the unable to record but as a BT engineer he was unable to help with the TalkTalk TV plus box , still unable to record anything, have tried all advice, except factory re-set.
I would like a new box please.
I cannot find a place to put my account number on my profile but have put my telephone number.
All broadband tests are clear so the connection looks fine.
Can you perform a factory reset from the settings menu,
This will clear any corrupt files and set the hard drive back up.
This is the last thing to try before we replace the box.
Had same problem had to do factory reset. Worked can now play and record.wiped my recordings but could not watch any way.
A corrupt recording or file could have been present and wiping the hard drive and setting this back up may have been the only option to clear this.
