TalkTalk Wi-Fi Extender Kit
7 REPLIES 7
hosay299
Insightful One
Can I ask am I able to use the new Talktalk Wi-fi Extender Kit with the old one u did before this??
As I am now usning the basic one but the middle light is not GREEN but RED.
So would like to know if I set up the old one and then used the bite of the new one with the plug on and connected my Talktalk TV Box to it would it work.??
As I need the one with the plug one as I would plug the tv box into it in the wall??
As in have the old Wifi bite connected to my router then used the one with the plug in it down stairs where my box is???
or would i need to have both parts of the old wifi extneder and then use the one with the plug in it???
As per the basic info on this page: here
Hope u understand what I mean.
Do these device use much power when not in use???
Hope that help Joe R If so then give me a Kudos ( Click the Thumb up Button)
I am getting a little confused, must be my age.
I've not tested the old adapters with the new so not 100% sure, but I have seen a post a while ago where a customer did test this and they worked for him.
hosay299
Insightful One
Hi Oce Karl,
Was a Hard one to try aand say what i mean.
what i am asking is i have the old wifi extenders and looking at the new ones.
if i plued the bit in of the old one to my router like u do to pair them but then used the new one with the plug one and put that with my tv box connected to it woould it work
As the new wifi exender i see from the info the pluged one has to be pluged next to ur router where as i want it pluged in to my tv box so i can use the plug for the tv box on it in the wall
i am using the basic one at moment but the middle light keeps going to red.oragne not green.
so i am loking at making the new way work if it can so it is pluged in to a wall socket and not a exteshion lead.
so i use now this
Talktalk Basic kit.jpgUseing now
Have got the old wifi exentder kit
Talktalk Old wifi exentder.jpgOld wifi kit
So if i used the bit on the left of the above where it PLUGS into the router
would that bite work with the new one with the plug one as shown below
Talktalk New wifi.jpgNew wifi one
or would i need both of the old wifi exender kit plugged in then the pluged one above
as does the new one work either way round
Could u ask the product team ???
so could i used these bites from either like this
talktalk wifii could work.pngPart one from the old wifi extender and Part 2 from the new Wifi extender
The product teams have not tested the old with the new, and can only confirm the new extenders work with the same extenders.
You can try pairing old and new side by side in a double wall socket and see if the pair up and the lights go green.  If not you may need to use the same models.
hosay299
Insightful One
Ok tHanks who do i talk to get the new ones and if they do not work am i able to return them.???
hosay299
Insightful One
Bump oce karl????
You can chat to our customer teams regarding the extra adapters but there will be a charge for these.
hosay299
Insightful One
Thanks getting some help from someone on the matter as seems not as simple as i was thinking.
