TalkTalk Youview Box issue.
No Problem 🙂
Box should arrive tomorrow, possibly Saturday if the couriers are busy.
loynsr
Hi did swapping the box resolve the issue as im havingt exactly the same problem with my new talk talk youview box and have only justy started my sertvice.
evets 1959
Hi I'm also having same issue with my NEW TV plus box, did you resolve the issue, my old box works fine, but it is very old and needed upgrading to use with apps ie NOW TV, any response  would be appreciated as customer service is a nightmare
evets 1959
Hi I've got the same problem did you resolve
evets 1959
Hi I've  got the same problem, did you resolve
evets 1959
Did you resolve  your TV box issue, I have the same problem
givenup
Can you try with the booster switch off? If a signal from a booster is too strong it can cause a bounce back interference.
Hi  evets 1959
Please can you create a new thread, we can then look into this further.
