TalkTalk box randomly shuts down
7 REPLIES 7
My TalkTalk box has started to randomly switch off.
The only way to get it up and running is to remove and plug in mains cable.
Means I can’t rely on it recording.
Any suggestions would be great.
Thx Barry
Have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
Hope it works but if not then please let us know and I’ll flag for further assistance.
Did the factory reset as instructed.When trying to order a film last night, which by the way I couldnt cause my pin wasnt recognised the box just shut down.
I can feel the harddrive is still spinning but I still have to remove and replace power lead to get it active again.
Cheers Bazz
I've escalated to the OCE for you.
For a quicker reply can you please ensure you have your personal information up to date in your profile. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
If you are unsure of your phone number, you can find this in My Account or dial 17070 from your land line phone and this will confirm the number for you.
Thank you
Ok.
Thanks for quick reply.
Cheers Barry
Hi Barry
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
Thx.
New box arrived,all installed and working perfectly.
Great service.
Cheers Barry
Glad to help.
