Just sits on waking up screen and when first turned on makes a few beeping noises.
Solved! Jump to the Best Answer.
Hi @RacAnd
Due to the current Coronavirus situation, the OCEs are very busy and there will be more of a delay to get a TalkTalk response. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk have responded to you, otherwise, this will just put you further down the queue.
Hi RacAnd
I'll get a replacement Box sent out to you,
New box arrived yesterday and working fine. Many thanks for your help.
Andrew
Excellent, Glad I was able to help.
