Talktalk Plus box has stopped recording
ANSWERED
4 REPLIES 4
Box keeps stopping and freezing so has to be rebooted 3 times an evening.  Everything we record will not play - it either goes to a blank screen or says failed to record.
Solution
Hi @Bernietaylor
Try a Maintenance reset as follows, OPTION 2 keeps your recordings :
Turn the box off, then unplug the power lead for about 10 minutes.
Re-plug in power  lead.
  1. Ensure the YouView Box is switched off and is currently connected to the router (the YouView Box will require an internet connection).
  2. Power on YouView using button at the back of the YouView Box.
  3. Start YouView using the power button on the YouView Box front panel and then quickly press and hold both the + and – buttons on the front panel. If you haven’t pressed the buttons together by the time 'YouView Waking Up' is displayed, or you see the 'YouView please wait...' message then try again.
  4. Let go of the + and – buttons once the 'Huawei – Maintenance Mode menu' is displayed.
  5. The + and – buttons on the front panel will navigate the menu. Keep pressing the – button until 2  “factory reset keep recordings” option is highlighted.  If you go past the option, simply press the + button to navigate back to the option.
  6. Press the power button on the YouView Box front panel to select the option. This will bring up some information and ask 'Do you want to proceed?'. Press the power button again to confirm.
  7. The YouView Box will now show a progress bar as it downloads software from the internet and installs on the YouView Box. This may take several minutes. Once complete, the YouView Box will restart.
  8. Once the YouView Box restarts, the YouView Box will show the initial setup wizard. You will need to run through the setup wizard including tuning the channels.
You will then need to reset your personal settings (such as parental controls / ANTENNA OUT / Surround Sound etc.) and also reset your scheduled recordings (might be worth taking a note of future recordings before doing this so you don’t miss any).For some reason ANTENNA OUT is disabled by default so you will need to reapply this from Settings Menu > Picture and Sound.
If you do NOT have any recordings that you want to keep :
Blue YV /Menu button on remote > Settings > Factory reset. This option will re-format the hard drive and reinstall the system on your box and you will lose all recordings.
Hi Bernie
Try the suggestion from fre55die and let me know how you get on.
Hi Karl
This worked for me thanks.
Bernie
Excellent!
