Talktalk box
3 REPLIES 3
My Talktalk Youview box has been acting up for about 6 months, by pixelating the picture. At first it was a small amount of the screen, then it got worse and tonight it stop showing some channels completely. BBC1, BBC 2, BBC 4 and BBC news channel just showed a blank screen. I have tried retuning the Youview  box (4 times), but channels 1, 2, 9 and 231 do not show in the list of channels. I have checked all the cable connections, all are fine and the aerial is working as well because I find by disconnecting the Youview Box and plugging the aerial cable straight into my television, gives me all the channels including those not being found by the YouView box. Can anyone make any suggestions or is my box past it's best.
I'll replace the box for you and see if this helps.
Hi Karl, Thanks for your quick response, the new box has arrived, is all connected and working
No Problem 🙂
