Talktalk plus tv
11 REPLIES 11
antgatefc
hi, having been a talktalk tv customer for over 10 years, my tv box is getting a bit old, so how do you get an upgrade to tv plus box, any ideas?
OCE_Karl
Are you experiencing any issues with the box ?
antgatefc
My, you view box, is quite old now, and will not update, updates now.
It runs slow, and gets hot, i feel it needs an upgrade, how do i get one.
The box is over 12 years old
Tony
OCE_Karl
Can you please add your home phone number or Account number to your Community Profile.
We will not attempt to call you, this is so we can locate your account and run tests on your line if required. We will then reply via this Community.
If unsure of your phone number, and if your line is working simply dial 17070 from your land line phone and this will confirm the number for you. Alternatively these details can be found within My Account online or may be on the heading of any paperwork you have received.
antgatefc
Same question as before, ?
Tony
@antgatefc Please wait for a response on your own topic, posting on other people's will only delay a response to them.
OCE_Karl
Hi Tony,
I'll get the box replaced for you.
antgatefc
Thank you
Tony
OCE_Karl
You're Welcome 🙂
antgatefc
Box arrived, and now set up, very easy.
Just one question, it had no remote control, do i have to order one, or is one on its way?
The remote on the setup part looks nothing like mine.
Once again, thanks for the new box
Tony
It is standard practice not to send replacement remotes, although there are different models they are interchangeable and your existing one should work with the new box.
OCE_Karl
Hi Tony
glad the new box arrived promptly.  As ferguson advises, the existing remote will work fully with the new box.
