Talktalk youview box faulty
5 REPLIES 5
We have a problem with our youview box.  It completely froze one day last week whilst watching TV.  I did a soft reset to get the box going again.  After a while it froze again.  So after another reset, we reset the box to factory settings.  Now it stuck on the setup box screen and won't go any further. The box is only about 3 months old.
We're happy to look into this for you. So I can find your details, can you update your community profile to include your home phone number.
If you don’t know your phone number, don’t worry, you can add your account number.
To check your phone number, you can dial 17070 from your home phone.
To update your info, go to 'My Settings'. then 'Personal Information', add your details, then click 'Save Changes' at the bottom when done.
You can also follow this link : Update My Profile
Let me know when you have done this.
Hello Karl,
I have updated my profile with my talktalk phone number.
I'll get a replacement TV out to you now.
Thanks for the quick response, do I send this faulty one back to you.
Yes please, our Teams can have a look at the box.
