Search instead for
Tv box keeps disconnecting from router
ANSWERED
Terry90
Like many other users I am having to reboot my HG633 router to activate the TV connection. This works ok for a day or so but then the tv light on router goes off and I have to reboot the router to re-establish connection.  Please can you help. Current software version on the router is 1.22t.
Solution
Hi Terry
I've updated the router firmware, try this and see if it is better.
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
Terry90
Many thanks - will check over next couple of days and advise.
No Problem 🙂
GYC61
Mine box has been doing the same for months.  Thinking of recommending my Mum join Talk Talk but not sure now as have contacted Talk before and they have been unable to resolve the issue.  Can you ugrade my box.
Hi GYC61
If you start your own thread (new message), wed love to help.
Weve found that posting in someone elses conversation makes it harder to follow when looking for an answer.
Its easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
GYC61
Sorry - will do
Terry90
Hi Karl
All looks to be working fine now.
Many thanks for your assistance.
Terry
Hi Terry,
That's great news, thanks for letting me know.
simonpjackson
I too am having to reboot my HG633 router to activate the TV connection. This works ok for a day or so but then the tv light on router goes off and I have to reboot the router to re-establish connection.  Please can you help. Current software version on the router is 1.22t.
simonpjackson
I also have the same issue that I am having to reboot my HG633 router to activate the TV connection. This also works ok for a day or so but then the tv light on router goes off and I have to reboot the router to re-establish connection.  Please can you update my firmware.
Terry90
Hi Simon
It is best to create your own thread for this as the OCEs will pick it up quicker.  The good news is that they will likely upgrade your firmware to v1.22.1t and it then works fine.
Best regards
Terry
simonpjackson
ok thanks I will do - Simon
