Search instead for
Tv box keeps disconnecting from router
simonpjackson
I too am having to reboot my HG633 router to activate the TV connection. This works ok for a day or so but then the tv light on router goes off and I have to reboot the router to re-establish connection.  Please can you update the firmware.
Hi Simon
Turn the router off at the mains for 2 minutes then turn on.
This should trigger a firmware update to your router.
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
simonpjackson
thanks, done, hopefully that will fix the issue now. Simon
No Problem 🙂
I can see the firmware has now updated.
