Tv box not working
4 REPLIES 4
Robm1970
My talk talk tv box has stopped working it switches itself off and freezes, it’s now not letting me switch channels. I’ve tried resetting it many times but nothing seems to work . How do I get a replacement box ?
Rob
Which resets have you tried?
Soft reset. To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works but if not then please let us know and I’ll flag for further assistance.
Robm1970
I’ve tried all of the resets if I want to use the box I have to keep turning it on and off but this only works for a short while
Rob
Robm1970
The box has stopped working completely now
Rob
OCE_Karl
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
