Tv box
3 REPLIES 3
VictoriaB
My you view box keeps seeming to get stuck on when trying to record a programme if tv/box is standby when recording scheduled starts.
Lights will be flashing like box is recording something and will turn on and able to see guide etc but I can’t then see any channels (just black screen and no sound) or watch any recordings and have to turn box off and on at the wall to restart it. The recording then shows up as failed to record.
it’s a fairly new box as my last one went off too (Different issue) loosing all my recordings So not keen to loose everything again if anyone can suggest a fix !
thanks
OCE_Karl
Can you try a Youview Maintenance Reset (Option 2: Keep Recordings).
Set the TV Box back up and see if performance improves.
VictoriaB
Cheers @OCE_Karl seems to be working again !
OCE_Karl
No Problem 🙂
