Tv problems
13 REPLIES 13
BecksC
Hi, we're having a lot of problems with our box. It freezes on various channels, we have to power off to reset. It works for a few hours before having to do again. Scheduled recordings are all failing. Subscribed channels disappear from the guide. Internet connection drops to the box. Unable to watch previously recorded programmes.
Any advise would be appreciated.
hosay299
Insightful One
Hi if u can wait for a oce to reply and help sort u out they should reply by next week do not work weekends any more.
if u can explain ur set up of ur eqipement in ur house  like is the tv box connected to the router or via powerlines.
How long have u had the box??
could u please fill in ur profile as it showing as not full filled in on here as it helps them link ur account on their other system.
please do not post any personal info on here as it is open to the public.
From what u are saying and the failing recordings sound like the box is going or there is a hard drive issue.
A bite of info of Forum:
To save yourself time, please make sure that your community profile includes your first & last names, broadband phone number & if possible an alternative contact number. This can be done by clicking on your Avatar picture then click on "My Settings" followed by:- Personal Profile > Personal Information
Hope that help Joe R If so then give me a Kudos ( Click the Thumb up Button)
fre55die
Hi @BecksC
I should try this as an OCE will suggest it. :
Turn the box off, then unplug power lead for a couple of minutes.
Re plug in power .
  1. Ensure the YouView Box is switched off and is currently connected to the router (the YouView Box will require an internet connection).
  2. Power on YouView using button at the back of the YouView Box.
  3. Start YouView using the power button on the YouView Box front panel and then quickly press and hold both the + and – buttons on the front panel. If you haven’t pressed the buttons together by the time 'YouView Waking Up' is displayed, or you see the 'YouView please wait...' message then try again.
  4. Let go of the + and – buttons once the 'Huawei – Maintenance Mode menu' is displayed.
  5. The + and – buttons on the front panel will navigate the menu. Keep pressing the – button until 2 “factory reset keep recordings” option is highlighted. If you go past the option, simply press the + button to navigate back to the option.
  6. Press the power button on the YouView Box front panel to select the option. This will bring up some information and ask 'Do you want to proceed?'. Press the power button again to confirm.
  7. The YouView Box will now show a progress bar as it downloads software from the internet and installs on the YouView Box. This may take several minutes. Once complete, the YouView Box will restart.
  8. Once the YouView Box restarts, the YouView Box will show the initial setup wizard. You will need to run through the setup wizard including tuning the channels.
Hi @BecksC
If you can add your home number to your Community Profile we can take a look.
BecksC
Hi, I've filled in my profile and did the factory reset. One other problem I forgot to mention is that the picture goes blocky at times.
Thank you for your advice so far but it's not fixed the problem.
BecksC
Hi, the box and router are connected by cable and I've had the box since April 2016. Thank you.
hosay299
Insightful One
I would say ther TV box is on it way out.
The team on here can get one sent out if that is the case just like the rotuer.
Does the box make a bizzing sound when u are near it - as that is what i found with our last box it was making a lound bizzing sound when u near it u can hear it.
BecksC
We've not been aware of any sounds coming from the box or router. Do you think I need a new box and router because I've had them both the same time?
Thank you for your advice.
Hi BecksC
The overall connection looks ok, no line issues showing.
I've had a look at the TV box remotely and all settings look ok, not seeing any errors on the hard drive, and no errors flagged from either of the receivers of the box.
First option is to swap out the router as this is also a few years old.  This is on the way to you and we can see if this makes any difference.
BecksC
OK and thank you. Will update when the router is here.
No Problem 🙂
Router should arrive tomorrow.
hosay299
Insightful One
Hi it can be a simple thing but it is just hard to pin point it so we just work at one thing at a time until we have covered things
BecksC
Hi, new router arrived today (postman wasn't able to deliver because I was away) All plugged in but getting the same problems.
Hi BecksC
I'll get the TV box swapped out and see if that is failing.
