Tv select boost not working
8 REPLIES 8
Just moved and nothing but problems and no help with chat. So far wasted 7 hrs with no results and my complaint hasn’t been responded to.
current issue is Select TV boost.
all select boost channels not working. The channels show on the guide, I can access the apps on the tv box. From this it can be shown that the internet is connected and working fine with the box as we can stream Netflix etc on the talktalk box, we can also get normal channels on the box with no signal issues. The only problem is the boost channels.
we have tried connecting the box to the router by direct cable and by power adapters. No difference
we have done all updates
we have completed two maintenance resets
we have factory reset twice also
we have no issue with downloading to multiple devices
**nothing wrong with router or tv box**
issue is with talktalk select boost only. There is either a block or something at talktalk end.
Channels we cant access:
Sky one - 301
Sky two - 304
Sky living - 302
Sky arts - 303
Sky sports news - 401
Real life’s - 305
Fox - 316
National geographic - 317
Comedy Central - 307
MTV - 309
Gold - 310
History - 327
Crime investigation - 328
We can see the guide for the channels but when we click the channels the screen is black.
Aimee.
Hi @AMitchell3009
I've drawn this topic to the attention of the TalkTalk Community support team and an OCE will respond to you right here to help you.
It's possible in the home move that the TV Boost hasn't been switched to your new line. The OCE's can fix that once you update your Community Profile.
You'll need to ensure your Community Profile Personal Information (Click here) includes your landline phone number and an alternate number (mobile recommended). Add, then scroll down and save changes. The Community support OCE will then be able to link this topic to your TalkTalk service account.
 Gondola - Volunteer 2017-2020
Hi @AMitchell3009
As Gondola advises, add your phone number to your Community Profile and i'll take a look at all the TV settings on your account for any issues.
I updated my information but still nothing.
Aimee.
All settings relating to your account are correct, nothing stands out.
I've asked my TV colleagues to have a quick look to see if they can see any discrepancies with the settings.
My TV colleagues have double checked everything for me and they can see no issues.
Can you perform a Youview Maintenance Reset
Set the box back up  and try a boost channel.  If not working, try going to MY TV in the youview settings and select some on demand content from your boosts.  This will force a subscription check.  Then try the channel again.
Hi AMitchell3009, the tv team have been in touch and told me that they believe this problem is fixed now. Please retest and let us know that it's sorted, or not.
Hi we’ve reset the box and these channels are still not working
Aimee.
I've passed this to networks to check for any VLAN or other exchange issues or to see if an Openreach multicast engineer is required to check the port for IPTV traffic.
