Two sky sports boost ipc6023
10 REPLIES 10
Since last Friday sky sports main event and sky golf have gone into ipc6023 mode. I’ve performed 3 maintenance rests(keep recordings) plus I’ve rebooted the router several times and removed and replugged every cable possible but still no joy. I know there is no live sport at the moment but I would like this sorted before it does. Please help.
Is this only happening on the 2 channels, do other subscription channels play ok ?
Yes the rest work fine. Just golf and main event. 402 and 406. Thanks
Can you please add your home phone number or Account number to your Community Profile so I can locate your details.
If unsure of your phone number, simply dial 17070 from your land line phone and this will confirm the number for you.
Yes Karl that has now been done.
Can you check the number on your profile, I'm not finding an account or service with that number.
Sorry this has now been updated to the correct number.
Can you power off the router for 30 minutes to end the current session, then I can check the logs to make sure a new session is created.
I have powered off the router as of 11.30
Hi Karl
What you have done has solved the problem.
All hail Karl. Much appreciated.
Mark
Glad the issue has been resolved for you.
