YVM102 Error
ANSWERED
4 REPLIES 4
Neil543
for the the last couple of days my freeview box hasn’t been connecting to the internet - my household connection is fine and i’ve tried a few fixes (checking the box and router connection, etc.) with no success.
Any ideas how I can get it working again?
thanks
fre55die
Hi @Neil543
Are you using Power Line Adaptors ? If so are all lights green and are they connected DIRECTLY in to sockets ie. not via a powerstrip ?
Youview checklist is here https://support.youview.com/youview-box/error-messages/fix-for-yvm102
Neil543
Hi, yes I am using power line adapters - they’re plugged into power banks but i’ve had them set up like that for 3 years with no previous issues... Tried every option on that support link as well but with no joy
fre55die
Solution
Hi @Neil543
It is recommended that they are plugged directly into socket. I know that when I tried using a power strip the speed dropped from 34Mbps to 6Mbps.
Are the PLA's showing 3 solid greens on both of them with no orange or red ever flickering on ?
Can you temporarily try connecting without the power strips.
https://help2.talktalk.co.uk/how-do-i-use-my-powerline-adapters-0
https://help2.talktalk.co.uk/powerline-adapter-troubleshooting-0
Neil543
Thanks for your help @fre55die,
we we tried the power line tests and then switched everything off for a little while. When we plugged everything back in and turned them on the router was found and it all *seems* to be working ok now.
thanks for your suggestions!
