You View + fault
4 REPLIES 4
My youview+ box suddenly showed no tv output signal. I plugged aerial direct to TV and picture was fine.
Has anyone experienced this fault?
Drew
check all your connections including trying a different HDMI cable if possible.
try retuning the box, first with the aerial disconnected to lead the memory and then with it back in, unless from what you say you can't even see the settings screen.
if the does not work,
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works but if not then please let us know and I’ll flag for further assistance.
Thanks fr8ys for reply.
Before trying your suggestions this morning , I switched on box and got into settings and checked software version and found online that there were a couple of recent updates so did this and the box now seems to be working normally. Hopefully it will keep on doing this. However if I have more problems I will try your suggestions. Thanks again.
Drew
Also meant to say I did a retune as well as system update.
Drew
Glad to hear this is working normally now.
