Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
YouView Box stuck on loading screen
PJWoodward
I have tried resetting the box using the instructions under Huawei YouView Maintenance Mode to no avail.  Is there anyway to transfer our recordings to a new box or are they going to be lost to us?
We had to have a new router within the last week, could this have anything to do with it?
Many thanks
In reverse order - I doubt the new router would have had an effect on the box, as you can't get it to work under maintenance mode.
Regarding your recordings, sorry they will be lost as you can't transfer them.
I've escalated to an OCE so they can discuss a box swap out with you.
Hi PJWoodward
There is no option currently to transfer recordings.
If the box is stuck in maintenance mode the only option is to swap out the box.  I'll get a replacement out to you.
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
PJWoodward
Thank you Karl
No Problem 🙂
