YouView Huawei DN372T
3 REPLIES 3
Hi I have just replaced my BT Youview DB2100 with the above, I'm bit  dissappointed, think it's laggy compared to the BT box, The guide takes longer to load so much so you can't fast flip through the channel list as it can't keep up. The remote is not as intuative. What's your opinion?
Have you checked that the software is up to date? You can use the BT box if you prefer.
Yes, I can use the BT box but that is quite old, and was expecting an improvement with DN372. The software is up to date, the user interface is the same on both so youview software seems standard. It appears to be the processing speed and or firmware
The model you have is generally quite reliable, it is an upgrade on the original box TalkTalk supplied. As for the remote control, well, they are all frustratingly different aren't they? Hopefully that wll be just a matter of time before you become accustomed to it.
