YouView Remote control replacement required
6 REPLIES 6
Hello TalkTalk,
I'm hoping you will answer my question on here as I cannot get through to you via any other means although I do appreciate the circumstances we are all having to contend with.
You sent me out a new YouView box about 3/4 weeks ago to replace the one I have but unfortunately no remote control came with the new unit.
I did raise a fault months ago that most of the buttons on the V1 remote I have do not work.
Thankfully I did mange to speak to someone on customer service a few weeks ago who said would send me a replacement.
Could you confirm that one is on the way (as I cant use the YouView box in all the ways I would like too)
I do understand that things are very busy for you. Although I would like an acknowledgement that a replacement will eventually be sent out.
Thank you and kind regards
Tbird2
3is there any updates please
Tbird2
I'll get a remote out to you.
Thank you so much Karl,
Kind regards
Tbird2
No Problem 🙂
Hi Karl,
I received the remote control today. Just wanted to thank you once again.
Kind regards
Tbird2
You're very welcome.
