YouView box keeps freezing
5 REPLIES 5
My YouView box keeps freezing up (no buttons then work on hand set).  This happens intermitantly about once every day or two.  It is cured by restartring the box and allowing it to go through the long start up procedure.
It often happens during fast forwarding or deleting pre-recoded programs.
I have done several factory resets and find no benefit as nothing improves.  It seems that there is something wrong with the internal workings of this otherwise great bit of kit.
Is it possible to arrange a replacement of the box as it is now driving me mad please?
Richard
Richard Snow
Can you please add your home phone number to your Community Profile so I can locate your details.
If unsure of your number, simply dial 17070 from your land line phone and this will confirm the number for you.
Please reply when this has been updated.
Telephone number added now
Richard Snow
I'll get the TV box swapped out for you.
That sounds great Karl, hopefully my problems will be solved.  Thank you
Richard
Richard Snow
No Problem 🙂
