Your view tv
1 REPLY 1
Grace5
Can anyone tell me how I turn off sound over in my your view tv?
Gondola
Hi @Grace5
Here's the advice article for the three types of remote control: TalkTalk Remote Control Guide
The Mute button is for sound off and on and is on the left side just below the centrally located sound volume up and down buttons.
Does the Mute button not work for you?
 Gondola - Volunteer 2017-2020
