Youveiw box not recording
1 REPLY 1
My Youview box is failing to record I have reset but this as not resolved the problem. How do I go about getting a new one?
Try a full factory reset for the settings menu.  This will reset the hard drive.
test new recordings and see if the will play back as normal.
