Youview DN3702 box not updating apps or players
1 REPLY 1
aliali
Been trying for a week to update apps and players unsuccessfully. Each time get the message "Unable to update apps and players, please try later". Most players work, iPlayer, Netflix, don't use NowTV so not sure if this works but have Amazon Prime player on ipad and wanted to use the update after receiving email that this was now available.
A
aliali
just to add that I reset the box, saving recordings, and updated channels all seemed to go through fine. Upgraded to wifi hub today and set up fine, just no update on players.
A
