Youview Remote
3 REPLIES 3
Leigh97
The volume buttons on Youview remote don't work anymore and alot of the other ones you have to press really hard for them to work.
If someone could help that would be great.
Hi Leigh97
I can send a replacement remote and a returns bag for your current one. Would you like me to arrange this?
Douglas61
Sightseer
My you view remote is erratic and very slow in changing stations and guide.
fre55die
Hi @Douglas61
Could you please start your own thread for support as each problem is individual and needs investigating separately.
IMPORTANT
Could you please also ensure that your community profile includes your PHONE NUMBER as OCE's will need this to tie up your screen name to your account. (click on your avatar to view the information > Settings > Launch Profile Wizard,put your phone number in box, then scroll to the bottom of page and click save)
