Youview box not recording/stalling
Newbie
My youview box has stopped recording.
Yesterday's recordings are blank.
I tried turning everything off and rebooting the box. Started okay but the one programme it did record is only a 30 min show but 4 hour later it is still recording and wont let me delete it.
Please help, I live alone and only have the TV for company
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works but if not then you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
Hi Katie
Please add your home phone number to your profile so I can pick this up for you.
