Youview box with a mind of it own
Insightful One
My youview box is randomly shutting down, it works okay for a couple of hours then for no apparent reason the tv signal drops and the box restarts. I tried soft resetting the box via the front buttons but it had no effect so I did a full reset but it's still happening.
The box is only about a month old...
Did you perform the factory reset from the youview menus ?
Insightful One
Hi Karl
Yes the factory reset was done using the youview menu option
