Search instead for
Youview plus box not powering on via remote.
domdorris
As the title says, my box won't come on via the remote. I have to turn off at the back and use front panel power button to wake it up. Fresh batteries in the remote too. Also the central white light on the front panel is quite dim even when the box is on, recording, etc. My previous box had quite a bright light until it went wonky too. All help appreciated in advance.
Dom
Hi Dom
Do other functions on the remote work, channel changes, volume etc ?
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
domdorris
Hi Karl.
Thanks for the speedy response. Yeah, once I've gotten the box powered up, the remote is responsive although occasionally, volume won't work despite the remote being set up to control TV volume.
I'll get a replacement remote out and see if this helps.
domdorris
Cheers Karl! Sorry for slow reply, I didn't get a reply notification and I only knew when I got a text from Royalmail to say delivering today....oops.
OK, Have a play round with this when it arrives and let me know.
domdorris
Hi Karl!
New remote received but I'm afraid that the box seems to be running slow; taking ages to navigate the menu and access apps. I've reset it but it's still the same. I'll keep an eye on it to see if it improves.
Dom
Hi Dom
When you reset the box, did you perform a Youview Maintenance Reset ?
domdorris
Hi Karl.
Yeah I performed the Maintenance Reset.
Ok,
The box freezing in some cases is under investigation by our TV teams.
