Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
Youview plus will not record.
jay792
Hello.
My youview box repeatedly fails to record programs, both from scheduled recordings and live tv.I have tried all community help suggestions, soft resets, maintainance resets and full router resets, it sometimes works for a day or two then starts failing again!
I called Talktalk helpline but they just told me to try everything that I have already tried. Are there any steps I can take to get a new box as this is the only answer to the problem that I can see.
Thank you all.
Jay
I've updated the router firmware as this could be causing the connection to drop and the recordings to fail.
Retest over the next couple of days and see if this has helped.
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
jay792
Thank you Karl,
I will let you know.
Jay
Jay
No Problem 🙂
jay792
Hello Karl,
Last night both iphones in the house were disconnected (android phones seem uneffected) from the wifi by the router with all attempts to reconnect being met with "password invalid" even though I know it's not. Would this be a result of the router firmware upgrade and do you know how I can reconnect?
Thank you
Jay
If you set a customer password yourself, the upgrade may have reset the settings back to default.
Can you try using the wifi details on the sticker on the router.
jay792
Hi Karl,
The youview box seems to be working well so far however, since the firmware upgrade, I still cannot get either of the iphones to connect to the wifi. I have changed the wifi password in the routers admin page, re-booted the router, reset both phones network settings, told both phones to forget the wifi network and started afresh but nothing has worked. Both phones either say password is incorrect, which I know isn't true or, if I can connect them, disconnect as soon as I try to use the wifi! The phones connect straight away to other wifi networks which leads me to presume that the fault isn't with the phones and all android devices in the house work fine!!
Any ideas as to how I can fix this?
Thank you.
Jay
Jay
Hi Jay,
I've separated your wifi channels for you. Now when you search for the wifi you will see 2 connections.  The one with 5G at the end is the 5Ghz channel.  The same password still applies to both.  So you can tet the connection by trying each one and seeing which one is best.
jay792
Hi Karl,
It seems that splitting the channels has done the trick, neither phone has dropped the signal yet.
Thank you ever so much for your help.
Jay
Jay
Hi Jay
Glad this has helped.
