connecting Youview to twin cable?
5 REPLIES 5
Visitor
Hi there!
I am trying to set up my TV BOX, but realised I have different type of aerial connection
( picture attached)
Do I need some kind of adopter or splitter to be able to connect it?
Thanks in advance
They look like connectors to a satellite dish. Do you have a regular TV aerial installed?
Visitor
unfortunately, it looks like i don't...
i guess some indoor antenna is the only option then?
It does depend on the reception in your area. You may get away with an indoor aerial, but YouView do recommend an external one if possible.
Visitor
yeah, i know. well , i guess i might have to cancel the TV deal then, sucks , was looking forward to it
An aerial is required, not only for the freeview channels but also for some on demand players as these use the aerial signal to identify your region.
