error message TTG 252
25 REPLIES 25
Over the past weeks I have tried to rent movies from Talk Talk using the talk talk box.  In each case I have been able to watch the trailer, but when I rent the movie and press play, I keep getting "Playback error TTG 252".  I have reported this problem twice to technical support at Talk Talk, each time being promised that the fault was logged and some one would get back to me n 72hour.  Alas no one did, I reported this fault again yesterday and now await for some one to contact me.  The movies in question were America Made and the Kindsman.
Rick
Hi Rick
I've drawn this topic to the attention of the TalkTalk Community support team of OCE's and they'll respond to you right here to help you.  As someone who is also currently experiencing this issue I can confirm you are not alone.
You'll need to ensure your Community Profile Personal Information (Click here) includes your landline phone number and an alternate number (mobile recommended). Add, then scroll down and save changes. The Community support OCE's will then be able to link this topic to your TalkTalk service account.
Leave your TV Box on smart standby and connected to your router, preferably directly with the supplied Ethernet cable, your router powered and connected to the line until you hear from the OCE's.  They'll check the TV Box, the router and the system and will have options to discuss with you.
 Gondola - Volunteer 2017-2020
Hi rick844
Can you add your home phone number to your Community Profile so I can locate your details.
Karl,
I have put my number on my profile
Rick
Can you put the home number or account number on your profile rather than the mobile number so I can locate your account details.
My home number is obscured for customer security
Can you - Hard Reboot TV box (using button at the back of the box)
Perform software update (Menu > Settings > Software Information > Update Software > Press OK on remote)
Load More TV (TalkTalk/More TV button on remote)
Select a boost / content.
I have carried out your instruction, I then tried a movie. The same message came up "playback error TTG-252.
Rick
I am being/have been billed for movies I am unable to watch due to a technical fault with Talk Talk. I have reported the fault numerous times and nothing has been rectified.
Did you try my previous advice?
Can you tell me the movie that was failing so I can check this and make sure you are not billed for it.
In total I have tried two movies twice, they are the Kingsman and America Made. Please see my other thread on the fault, I have carried out your instruction and it has not rectified the fault
I've processed a refund for the 2 movies.  also I've raised this to our TV teams to have a look and see if they can see an issue.  I'll let you know as soon as they reply.
Can you power off the box via the button at the back for 5 minutes, then power back on and try one of the movies again ?
I have carried out what you have asked. I then went to hire the "Kingsman", I entered my pin number. An instruction said that the movie is now in "My Stuff" folder, I go to this folder select the movie and it says the has "29 days to start the movie". I press OK to get the movie to play, the screen then returns to the PIN screen, I did this 3 times. I now have the Kingsman movie 3 times in the "my stuff" folder. In other words it has not worked and I have three movies I can't watch again. If we need to change my talk talk box then please change it, my patients is becoming very thin.
Rick
Hi Rick,
I've passed this back over to our TV guys and will see what they say.
Thanks Karl, they tried fixing the problem but they could not do it. They have passed it up to the engineering deptarment. I have also beenjoy charged for two more film I selected during the testingredient with the TV guys and unable to watch.
Rick
Is there any update, I have heard nothing since the problem has been passed to engineering
I've emailed our TV teams to see whats happening with this.
Our TV Teams have asked if you can try a Youview Maintenance Reset (Option 4: Keep Recordings).
Then try again.  They have fully tested the movies here and are unable to recreate. The are also not seeing any other reports, which is unusual for a popular movie such as this.
I have carried out the procedure as instructed, I now have fault code TTG 216 and I am unable to see any film at all. I have now had enough, if this problem is not sorted by the end of this I will cancel my TV subscription.
