is anyone else having issue with now tv on youview box?
5 REPLIES 5
talktalk youview box say that now tv is no longer supported on this device. anyone else have this issue?
sdjackson
Problem Solver
If you have the DN370T box then yes, as you've found Now TV is not supported on that box any more.
Make sure your phone number is in your profile on this forum (don't post it publicly in a message) and an OCE (TalkTalk staff member) will be along to help, usually during the working week.
Normally, if you subscribe to TalkTalk TV, they will send you the more recent DN372T so you can access Now TV.
thanx for the heads up
sdjackson
Hi jacko2120
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
thank you so much for your help
sdjackson
No Problem 🙂
